accessRights.enable |
Indicates and controls whether (TRUE) or not (FALSE) logging of events is enabled. Logging occurs if and only if Enable is TRUE, Local_Time is on or after Start_Time, and Local_Time is before Stop_Time. If Start_Time contains an unspecified datetime, then it shall be considered equal to 'the start of time'. If Stop_Time contains an unspecified datetime, then it shall be considered equal to 'the end of time'. Log records of type log-status are recorded without regard to the value of the Enable property.
A propriedade enable do objeto accessRights pode ser lida e escrita utilizando um tag normal (IOTag).
accessRights-<endereçoDoObjeto>.enable |
<tipo> = 34 |
<propriedade> = 133 |
