accessPoint.transactionNotificationClass |
Specifies the instance of the Notification Class object to use for event-notificationdistribution of Access Transaction Events. If this property is not present, then the Notification Class specified by the property Notification_Class shall be used for Access Transaction Events.
A propriedade transactionNotificationClass do objeto accessPoint pode ser lida e escrita utilizando um tag normal (IOTag).
accessPoint-<endereçoDoObjeto>.transactionNotificationClass |
<tipo> = 33 |
<propriedade> = 309 |
