accessPoint.numberOfAuthenticationPolicies |
Specifies the number of specified authentication policies. This property shall always have a value greater than zero. If the value of this property is changed, the size of the Authentication_Policy_List array and the size of the Authentication_Policy_Names array, if present, shall also be changed to the same value.
A propriedade numberOfAuthenticationPolicies do objeto accessPoint pode ser lida e escrita utilizando um tag normal (IOTag).
accessPoint-<endereçoDoObjeto>.numberOfAuthenticationPolicies |
<tipo> = 33 |
<propriedade> = 289 |
