accessPoint.musterPoint |
Indicates whether this Access Point generates muster access events (TRUE) or not (FALSE). A muster event is generated by setting the Access_Event property to MUSTER after an access credential has been presented at the access point. It is a local matter as to whether a muster event is generated for unknown credentials.
A propriedade musterPoint do objeto accessPoint pode ser lida e escrita utilizando um tag normal (IOTag).
accessPoint-<endereçoDoObjeto>.musterPoint |
<tipo> = 33 |
<propriedade> = 287 |
