accessPoint.lockoutRelinquishTime |
Specifies the time, in seconds, to delay after the Lockout property has taken on the value TRUE, before automatically relinquishing the lockout state. The lockout state is relinquished by setting the Lockout property to FALSE. A value of zero indicates that the lockout state will not automatically be relinquished.
A propriedade lockoutRelinquishTime do objeto accessPoint pode ser lida e escrita utilizando um tag normal (IOTag).
accessPoint-<endereçoDoObjeto>.lockoutRelinquishTime |
<tipo> = 33 |
<propriedade> = 283 |
