accessPoint.failedAttempts |
Indicates the current count of successive failed access attempts. Any successive failed access attempt shall increment the value of this property. This property shall be set to zero when a successful access attempt occurs or when the property Lockout becomes FALSE.
A propriedade failedAttempts do objeto accessPoint pode ser lida e escrita utilizando um tag normal (IOTag).
accessPoint-<endereçoDoObjeto>.failedAttempts |
<tipo> = 33 |
<propriedade> = 273 |
