accessPoint.activeAuthenticationPolicy |
Specifies the active authentication policy. The active authentication policy of this object shall be one of 'n' authentication policies, where 'n' is the number of authentication policies defined in the Number_Of_Authentication_Policies property.
A propriedade activeAuthenticationPolicy do objeto accessPoint pode ser lida e escrita utilizando um tag normal (IOTag).
accessPoint-<endereçoDoObjeto>.activeAuthenticationPolicy |
<tipo> = 33 |
<propriedade> = 255 |
