accessPoint.accessEventTag |
Numeric value which identifies the access transaction to which the current access event belongs. Multiple access events may be generated by a single access transaction. The value of this property shall increase monotonically for each new access transaction. It may be implemented using modulo arithmetic.
A propriedade accessEventTag do objeto accessPoint pode ser lida e escrita utilizando um tag normal (IOTag).
accessPoint-<endereçoDoObjeto>.accessEventTag |
<tipo> = 33 |
<propriedade> = 322 |
