accessPoint.accessDoors |
Specifies the references to those Access Door objects whose Present_Value properties are commanded after successful authorization. If this Access Point object does not command Access Door objects (e.g., muster point), or is used to control access to other resources or functions, or commands other objects, then this array shall be empty.
A propriedade accessDoors do objeto accessPoint pode ser lida e escrita utilizando um tag normal (IOTag).
accessPoint-<endereçoDoObjeto>.accessDoors |
<tipo> = 33 |
<propriedade> = 246 |
Um string contendo um XML com um valor do tipo <SequenceOfBACnetDeviceObjectReference>.
