accessDoor.doorPulseTime |
Indicates the maximum duration of time, in tenths of seconds, for which the door will be unlocked when the Present_Value has a value of PULSE_UNLOCK, after which time the Present_Value shall be automatically relinquished at the priority that established the PULSE_UNLOCK command.
A propriedade doorPulseTime do objeto accessDoor pode ser lida e escrita utilizando um tag normal (IOTag).
accessDoor-<endereçoDoObjeto>.doorPulseTime |
<tipo> = 30 |
<propriedade> = 230 |
