accessDoor.doorExtendedPulseTime |
Indicates the maximum amount of time, in tenths of seconds, which the door will be unlocked when the Present_Value has a value of EXTENDED_PULSE_UNLOCK, after which time the Present_Value shall be automatically relinquished at the priority that established the EXTENDED_PULSE_UNLOCK command.
A propriedade doorExtendedPulseTime do objeto accessDoor pode ser lida e escrita utilizando um tag normal (IOTag).
accessDoor-<endereçoDoObjeto>.doorExtendedPulseTime |
<tipo> = 30 |
<propriedade> = 227 |
