IsUserMemberOfGroup
IsUserMemberOfGroup
IsUserMemberOfGroup(GroupName, [UserName])
This method checks if a user belongs to a certain group. It contains the following parameters:
•GroupName: Name of a user group to check
•UserName: Name of a user to check. If this parameter is omitted or is an empty String, this method considers the user currently logged in Elipse Water Viewer
This method returns True if a user belongs to the GroupName group or False otherwise.
