Context
Context
Context(ContextName)
Returns an object implementing the context indicated by the ContextName parameter, which must be a String surrounded by quotation marks. This method fails if no object on the upper hierarchy of the object calling this method implements that context. The following contexts are available:
•Container: Server and Viewer objects, that is, objects inserted in project files or on folders inside projects
•Area: Alarm Areas, or any server object whose IsAlarmArea property is set to True
•Device: Check Valve, Consumer Cluster, Flow Control Valve, Generic Item, Hydraulic Plant, Link Node, One-Terminal Measuring Point, Pipe, Potable Water Consumer Equivalent, Pressure-Reducing Valve, Pressure-Sustaining Valve, Pump, Shutoff Valve, Tank, Throttle Control Valve, Two-Terminal Measuring Point, Water Distribution Network, and Water Supply Point objects
In addition, the following specific contexts are available:
•Station: Hydraulic Plant object
•WaterCheckValve: Check Valve object
•WaterConsumerCluster: Consumer Cluster object
•WaterConsumerEquivalent: Potable Water Consumer Equivalent object
•WaterDistributionNetwork: Water Distribution Network object
•WaterFlowControlValve: Flow Control Valve object
•WaterGenericItem: Generic Item object
•WaterLinkNode: Link Node object
•WaterMeasuringPoint: One- and Two-Terminal Measuring Point objects
•WaterPipe: Pipe object
•WaterPressureReducingValve: Pressure-Reducing Valve object
•WaterPressureSustainingValve: Pressure-Sustaining Valve object
•WaterPump: Pump object
•WaterShutoffValve: Shutoff Valve object
•WaterSupplyPoint: Water Supply Point object
•WaterTank: Tank object
•WaterThrottleControlValve: Throttle Control Valve object
NOTE
Context names are case-insensitive. To check the context to which an object belongs, open its Properties Window, select the Item tab, and then check its valid contexts in the Contexts frame. In case an object defines more than one context, their names are presented in alphabetical order, separated by commas.
