Session Information
Session Information
This section contains information about the properties of a Session Information (SessionNodeBase) object. This object does not contain events nor methods associated to it.
NOTE
Using brackets when referencing this object in scripts, such as "[?Server].Clients.RemoteDomains", is mandatory.
The currently available Session Information objects are the following:
•RemoteDomains: Remote Domain connections
•Studios: Elipse Water Studio connections
•Viewers: Elipse Water Viewer connections
