Devices
Devices
This section contains information about the Device-type objects of the Hydraulic Model. The available devices on this section are the following:
•Check Valve
•Flow Control Valve
•Generic Item
•Level Control Valve
•One-Terminal Measuring Point
•Pump
•Pressure-Reducing Valve
•Pressure-Sustaining Valve
•Shutoff Valve
•Submersible Well Pump
•Tank
•Throttle Control Valve
•Two-Terminal Measuring Point
•Water Supply Point
•Water Supply Well
