ModelDriver64
ModelDriver64
Text Configures the path of a library file (DLL file) for importing or syncing an Hydraulic Model from an external database. The default value of this property is an empty String. For more information about this library, please contact Elipse Software.
NOTES
•This property is available for Elipse Water in its 64-bit version. For its 32-bit version, please check the ModelDriver property.
•The library file pointed by this property must be a 64-bit version, which differentiates from its 32-bit version by having a "64" suffix in its name.
•Importing or syncing an Hydraulic Model depends on the Elipse Water Studio used, 32- or 64-bit, both available on the 64-bit version.
