DeleteItem
DeleteItem
DeleteItem(ID)
Deletes the element indicated by the Id parameter of the Hydraulic Model.
NOTES
•The element indicated by the Id parameter is deleted together with all references and connections.
•For more information about the format of the Id parameter, please check the ID property, common to all devices.
