ScreenAlignment
ScreenAlignment
Enum Controls the alignment, given by Elipse Water Viewer, of all Screens that do not specify a value different from default. Possible values for this property are:
The next figure shows an Elipse Water Viewer's contextual menu at run time, with the respective configuration options of this property.
Options for Elipse Water Viewer's ScreenAlignment property at run time
