Other Settings
Other Settings
Users can configure Elipse Water's Scripts Editor, as well as other options for Domain files by using the Tools - Options menu, where users have access to the configuration window on the next figures.
The General tab configures general behaviors of object Editors and Domains.
General tab
General tab
Available options for General tab
Option
Description
Activate Script Editor
Activates the Scripts Editor when double-clicking an object
Open Properties Window
Opens the Properties Window when double-clicking an object. NOTE: The Properties Window can also be opened by using the shortcut keys ALT + ENTER or ALT + Double-click
Show close button on active tab
Allows closing the active tab when clicking its Close button. Clearing the selection of this option places the Close button on view's right side
Always ask before stopping the Domain
If this option is selected, displays a confirmation message when stopping a Domain using the Runs or Stops Domain Runs or Stops Domain (SHIFT + F9) option on the Default toolbar
Show warning messages from Find/Replace window
If this option is selected, all messages displayed on message boxes during find and replace operations on the Find and Replace window are always displayed. NOTE: If this option is in an undetermined state Undetermined state, this indicates that users deselected the Always show this message option of the message box for some messages and not for other messages
The Scripts Editor tab configures Elipse Water's Scripts Editor.
Scripts Editor tab
Scripts Editor tab
Available options for Scripts Editor tab
Option
Description
Collapsible nodes
Allows hiding or displaying code blocks in scripts
Margin size
Size of the margin containing code blocks
Line numbering
Enables line numbering in Scripts Editor
Margin size
Size of the margin containing the line numbering
Tab size
Determines the number of tab spaces
Font
Determines the name of the font used in Scripts Editor
Size
Determines the size of the font used in Scripts Editor
NOTE
Close all open Scripts Editors to apply these changes.
The Files tab allows enabling or disabling a CRC (Cyclic Redundancy Check) verification.
Files tab
Files tab
Every time a project or library is created, Elipse Water internally stores a CRC code for this file's data. Every time a file is opened, this CRC code is then checked. In case that check fails, that is, its CRC code does not match data, loading this file is aborted, indicating file's data corruption. This may be due to hardware failures such as memory, network, or storage device, among others.
However, if a project created with the latest version is then modified in a version before 1.00.019 build 203, this CRC code is not updated. This means that a file cannot be opened again in new versions, because its CRC check fails, even though this file is not effectively corrupted. To solve this question, enable the Ignore CRC check option. Thus, a project can be opened in the current version.
In this case, this option must remain enabled until all objects edited in previous versions are saved by the current version, which then updates its CRC code.
NOTE
It is not recommended to edit project files in older versions of Elipse Water and then open these files in new versions, because there is no guarantee that file settings are not lost during this procedure.
