Accessing Elipse Water Properties
Accessing any server object in a script that executes in Elipse Water Studio can be performed by using the Application.GetObject directive. The word Application returns the application object related to the current object's context, and the GetObject method searches on the loaded Domain in Elipse Water Studio for an application or Domain object with the provided path. In the next example, the CustomConfig event is triggered in Elipse Water Studio.
Sub XControl1_CustomConfig
  Application.GetObject("Data.DemoTag1").DocString = "Documentation"
