Operation Diagram
Operation Diagram
After configuring a data structure, users can start developing Distribution Networks' operation diagram. To make it easy to create operation Screens, Elipse Water allows an Hydraulic Model's diagram, created in Water Configuration object, to be used as the basis to import all devices to a Screen in a project file. This tool uses a set of graphical libraries, which is distributed with Elipse Water, capable of interacting with a data object.
