Measurement Sources
Measurement Sources
When inserting Measurements, users must always consider the location where that Measurement is requested. Inside a Measurement, whether Analog or Discrete, users can insert one or more Measurement Sources, indicating how information is received by an application. These Measurement Sources can be input ones or from a Hydraulic Study. To insert a Measurement Source, right-click a Measurement, select the Add option and then the type of Measurement Source, according to the next image.
Option to add a Measurement Source
The available types of Measurement Sources are described on the next table.
Types of Measurement Sources
Measurement Source
Description
Operator
This value is informed manually by the operator of the hydraulic system
Scada
This value is received by an I/O variable
CCLink
This value is received by another Control Center
Billing
This value is received by the billing system
Calculated
This value is calculated
Database
This value is received using a table field from a database. NOTE: The application is responsible for configuring a Query and the methods to retrieve this data from a database
TopologyProcessor
This value comes from a Topology Processor-type Hydraulic Study
ExternalReader
This value comes from an External Reader-type Hydraulic Study
By default, each Measurement is created containing an Operator-type Measurement Source. For input Measurement Sources, except for the Operator-type Source, users must configure which variable provides their values. This configuration is performed in the Tag property of an Analog or Discrete Measurement.
