Keyboard Shortcuts |
The next table contains the available shortcut keys on Task Panel.
Available shortcut keys on Task Panel
Shortcut Key |
Description |
Application or menu key |
Opens the contextual menu of the item selected on Displays and Connections tabs |
CTRL + TAB |
Toggles focus between the Task Panel and the Displays |
ENTER |
Selects the current Display on the Display area |
F5 |
Updates all connections on the Connections tab |
H |
Shows or hides the selected Display |
SHIFT + TAB |
Browses the tabs, from right to left |
TAB |
Browses the tabs, from left to right |
