Vertical Scale
Vertical Scale
The Vertical Scale of a Display contains the options shown on the next figure. To open this window, right-click a Vertical Scale and select the Edit option.
Numeric scale window
Available options on the Numeric scale window
Option
Description
Title
Title of the Vertical Scale
Show Title
Enables viewing the title of the Vertical Scale
Top
Maximum value of the Vertical Scale
Bottom
Minimum value of the Vertical Scale
Show Gridlines
Enables viewing grid lines on the Vertical Scale relative to the Time Scale
Digital axis scale
Adjusts the Vertical Scale to view digital or discrete variables
Auto fit
When selecting this option, the Pens that use this Vertical Scale are permanently fitted according to the visible period. In this mode the Vertical Scale cannot be dragged
In addition to edition options, the contextual menu of a Vertical Scale contains the Delete option, which removes the Vertical Scale, and the Fit option, which fits the Pens according to the visible period.
NOTE
Displays with only one Vertical Scale do not allow excluding this Scale.
Moving the mouse wheel over a Vertical Scale applies a zoom in or zoom out operation, depending on the rotation direction and on the mouse focus.
When the mouse pointer is over the Vertical Scale to the left of a Display, the Add Vertical Axis and Remove Vertical Axis options are shown under the legend and allow, respectively, adding or removing a Vertical Scale. The Vertical Scale created is linked to the corresponding Plot Area and users can link Pens to this specific Vertical Scale.
To remove a Vertical Scale, click the Remove Vertical Axis option, which corresponds to the Delete options of its contextual menu. The dialog box on the next figure is shown, requesting a confirmation for this removal operation.
Confirming the removal of a Vertical Scale
NOTES
•Pens linked to the removed Vertical Scale are also removed from the Plot Area.
•Users cannot remove the original Vertical Scale from a Plot Area.
