Elipse Power: PowerEngine and Electrical Studies
•Fixed an error in the Load Shedding module where the ValidOutput property of the Scenarios displayed the value False when the module was deactivated and the Switch that triggered that Scenario was already open. This bug occurred since v3.5.341.
•Fixed the behavior of the Self-Healing module, which was aborted when it found rings on the network and these rings could be ignored. This bug occurred since v4.7.119.
•The Self-Healing module now correctly identifies and aborts cases when the triggered Switch is part of any Branch with inconsistent current samples. This bug occurred since v4.7.119.
