Elipse Power: Data Objects
•Added the NormalState property to Switch (PowerSwitch), Breaker (PowerBreaker), Switch Fuse (PowerSwitchFuse), and Recloser (PowerRecloser) objects.
•Changed the active Source of the default Load Shedding Measurement for Loads and Distribution Loads and not inserted the LoadShedding Source for this Measurement.
•Created support for expressions inside Semantics' descriptions of types of Commands defined in the Power Configuration object (PowerConfig).
•Created the StrokeColor property on Elipse Power's data objects.
•Created the data object PowerDistTransformer, which represents a Distribution Transformer.
•Created a 220V voltage level on Power Configuration, with a default blue color.
