License Type Information
This section contains information about the properties of a License Type Information (LicenseCounterNode) object. This object does not contain events nor methods associated to it.
NOTE
Using brackets when referencing this object in scripts, such as "[?Server].License.IoDrivers", is mandatory.
The currently available License Type Information objects are the following:
•ViewersControl: Elipse Power Viewer licenses
•ViewersOnly: Elipse Power Viewer Only licenses
•Studios: Elipse Power Studio licenses
•IoPoints: I/O points licenses
•StorageTags: Storage Tags licenses
•RemoteServers: Remote Domain server licenses
•RemoteClients: Remote Domain client licenses
•OpcServer: OPC DA Server licenses
•IoDrivers: Driver licenses for any Driver, that is, unlimited Driver licenses
•IoDriversId<nnn>: Driver licenses, where nnn is a number between 1 (one) and 65535, when there are licenses for a specific input and output I/O Driver ID
•UaServerTagLimit: OPC UA Server licenses
•PowerSubstations: Substation licenses
•PowerFeeders: Feeder licenses
•PowerMeasurements: Measurement licenses
•WindTurbines: Wind Turbine licenses
•PowerPvArrays: Photovoltaic Array licenses
•PowerInverters: Inverter licenses
•PowerFlowInputs: Power Flow Input licenses
•LoadShedBrakers: Load Shedding Breaker licenses
•PowerLoads: Load licenses
•PwrViewGeneratorLoads: Schematic View Generation Load licenses
•StateEstimatorLoads: State Estimator Load licenses
•DistLoadModellingLoads: Distribution Load licenses
•SelfHealingBreakers: Self-Healing Recloser and Breaker licenses
