RenderQuality
RenderQuality
Enum Controls a Screen's drawing quality. Possible values for this property are the following:
•0 - rqDefault: Screen's drawing quality uses the value defined in Viewer's RenderQuality property. This is the default value of this property, even in applications created on versions earlier than 4.0
•1 - rqNormal: Forces the normal quality mode (GDI, Graphics Device Interface) for drawing this Screen
•2 - rqHighQuality: Forces the high quality mode (GDI+) for drawing this Screen
The next figure displays a Screen's contextual menu at run time, with all respective configuration options for this property.
Options of a Screen's RenderQuality property
