Export
Export
Export(ExportFormat, [ExportFileName], [ShowSaveDlg])
Exports a Section Report to a file specified in the ExportFileName parameter according to the format specified in the ExportFormat parameter. The available options for the ExportFormat parameter are the following:
•PDF: Exports data to a file in PDF (Portable Document Format, default) format
•Excel: Exports data to a file in an Excel spreadsheet format (with an .xlsx extension)
•HTML: Exports data to a file in HTML (Hyper Text Markup Language) format
•RTF: Exports data to a file in RTF (Rich Text Format) format
•Text: Exports data to a file in Text format
The ShowSaveDlg parameter is optional and indicates whether the default window to save files is displayed or not. The default value of this parameter is False. If the ExportFileName parameter is omitted, the Section Report is saved on the Domain folder with a default name.
NOTE
Users can use either a .txt extension or a .csv extension for the Text export format. CSV (Comma-Separated Values) files are more suitable for importing into databases or Excel spreadsheets.
