IgnoreFlipHorizontal
Boolean This property forces the image loaded in this object to keep the original orientation relative to the horizontal axis, regardless of the configuration of the FlipHorizontal property, common to all Screen objects. The default value of this property is False.
NOTES
•This property is only effective if a Picture object was not converted to symbol, that is, its Convert property is configured with the value 0 (zero).
•For objects created in versions before the implementation of this property and opened in applications starting with version 6.7, the value of this property is set to True.
