TotalFailedWrites
TotalFailedWrites
Number Indicates how many operations of .e3o files failed and were discarded since a database connection was activated. This property can be automatically zeroed in several situations, such as:
•When deactivating a Database object
•If the E3DBEngine process is closed for any reason
•If the configuration parameters of a connection from a Database object are changed
