Properties
Properties
This section contains information about the properties of a Section Report's Layout (SectionReport) object.
NOTE
All properties described here are part of a SectionReport object, which is encapsulated inside a Section Report (E3SectionReport) object. These properties are only valid inside a Section Report's scope and cannot be accessed outside this object.
The available properties on this section are the following:
•MaxPages
•PrintWidth
•WaterMark
•WaterMarkAlignment
•WaterMarkPrintOnPages
•WaterMarkSizeMode
