Reports
Reports
•The Print method of a Section Report now contains a ShowPrintDialog parameter.
•A date and time with value "00:00:00" in a Section Report is now represented the same way it was represented in a Report object, deprecated in version 6.6.
•Now there is no option to insert new Reports (deprecated). Domains with deprecated Reports now show that situation as an error in the Domain Verifier.
•Updated the Active Reports component from version 16 to version 17.
