Security
Security
•Fixed an error when loading numeric properties saved in versions previous to version 5.0. This bug occurred since v6.5.4.
•The tree of Users and Groups is now always sorted. This bug occurred since v6.5.4.
•Now, when loading a list of members of a local group, the users from external domains belonging to that group have their paths correctly loaded and the list does not show anymore members that are not users. This bug occurred since v5.6.36.
•The Disable permissions check option was added to the configuration window of the Domain of E3 Admin, on the Properties tab. This bug occurred since v6.5.4.
•Reduced the loading time of the window to configure users and groups in remote Elipse Power Studios and Elipse Power Viewers. This bug occurred since v6.5.4.
•Now the only acceptable format for registering Windows users and groups in Elipse Power is the NetBIOS (DOMINIO\usuario) format. Older registrations will be updated. This bug occurred since v5.6.71.
•Fixed a small memory leak in E3 Server during the process of loading users in their respective groups. This bug occurred since v6.5.55.
•Performed optimizations when handling Windows users and groups. This bug occurred since v5.6.71.
•Now opening a Domain with many Windows groups or users must not have the same performance of a Domain without users or groups of the same type. This bug occurred since v5.6.71.
•Fixed a memory leak on the Permissions tab of the Users and Groups window on Elipse Power Studio. This bug occurred since v6.5.4.
•Using Viewer's IsUserMemberOfGroup method is now allowed for Windows users registered only via Windows groups. This bug occurred since v5.6.71.
•Removed the double confirmation to remove Windows users using the Members tab of a Windows group. This bug occurred since v6.5.4.
•Removed the options Move Up and Move Down from the Groups tab of users and groups on the Users and Groups window. This bug occurred since v6.5.162.
