TrendAnalysis
TrendAnalysis
•Improved TrendAnalysis support for displays with scale levels greater than 100%.
•Tags are now retrieved automatically after leaving an error situation.
•Implemented horizontal scroll bars on the Connections and Bookmarks tabs.
•Added support for more quality values from OPC standard.
•Now users can remove Plot Areas in any order via contextual menu of a Display.
•Error messages when loading files in TrendAnalysis' XML format are now more detailed.
•TrendAnalysis now allows users to select a scale of size for visual elements.
•Standardized the display of values and qualities in search modes.
•The file in CSV format exported by TrendAnalysis now indicates fields in more details.
•Added methods AddPen, AddDisplay, and AddPlotArea to the TrendAnalysis object.
•Added a column with the average value of a Pen on the Pens area of the Displays tab.
•Now users can add horizontal and vertical guide lines in TrendAnalysis.
