Scripts
Scripts
•Fixed the behavior of methods Application.GetObject and Application.Verify for objects inside Folders. This bug occurred since v4.8.50.
•Fixed an E3Run's unexpected close, which could occur when using the Application.GetObject method passing a path that ended in a property with a Nothing value. This bug occurred since v5.0.259.
