Scripts
Scripts
•Implemented the ProductString, ProductVersionMajor, ProductVersionMinor, and ProductVersionBuild properties in the Application object and created the E3ProductString, E3ProductVersionMajor, E3ProductVersionMinor, and E3ProductVersionBuild methods in the E3Globals module, used in Links and scripts.
•Implemented support for objects of the Viewer context in Studio's ListFiles method.
•The Application.Trace method is now also available in Elipse Power Studio and in Elipse Power Viewer and that message is registered in Elipse Power logs. In E3Run this method keeps recording messages in Domain's log files, in the format <DomainName>.txt, but also registers that message in Elipse Power logs.
•Implemented a tool to analyze script performance (profiler), which can be enabled in Windows Registry.
•Created the Events property in Elipse Power objects, which is a collection of events that allow adding scripts by script in any object.
•Elipse Power now can, by enabling it in Windows Registry, declare its script structure for an easy debugging in E3Run, Elipse Power Viewer, and Elipse Power Studio.
