Database
Database
•SQL Server's connection String is not deleted anymore when switching the window with the Change connection string option enabled. This bug occurred since v4.5.56.
•Oracle databases configured to use the TIMESTAMP data type are also forced to use a native ADO Driver, when executing an application and when in Elipse Power Studio as well. This bug occurred since v2.5.21.
•Fixed an error in the Test Connection option on the Configuration tab of a Properties Window of a database, which was not updating when switching the type of database. This bug occurred since v4.6.67.
•Oracle's reserved words are now surrounded by brackets, thus can be used as names of Fields, Tables, or Indexes, among others.
