Domain, E3 Server, and Hot-Standby
•Changed E3 Admin to detect when UAC (User Account Control) is turned off and to fail only if there is a need to elevate user privileges. This bug occurred since v3.0.348.
•Fixed a GPF that occurred when attributing an object to the Value property of a Block Element with an enabled scale (the EnableScaling property). This bug occurred since v0.1.7.
•Implemented an immediate release of Driver licenses when finishing the E3Run process, thus avoiding a lack of Driver licenses if the Domain is restarted very fast after an E3Run failure. This bug occurred since v3.0.200.
