Database
Database
•Fixed the processing of operation queues of Elipse Power databases that may generate files .e3o# (.e3o0, .e3o1, .e3o2, etc.) on Domain's folder when processing operations marked as ImmediateExecute. This bug occurred since v3.0.36.
•The ConnectionActive and TotalFailedWrites of a Database Server object now work correctly when used in Links.This bug occurred since v1.21.77.
•Elipse Power Studio now creates correctly on a folder relative to the current Domain the files .mdb declared with relative paths. This bug occurred since v0.1.24.
•Elipse Power Studio now applies immediately all changes performed in advanced properties of a Database, such as connection's network library with a SQL Server database. This bug occurred since v1.18.16.
•Fixed a possible lock that may occur in E3Run when creating a synchronous query to a database. This bug occurred since v3.1.170.
•Fixed an Oracle session leak that occurred whenever a connection was finished due to a command time-out. This bug occurred since v4.0.14.
•Fixed a problem in Oracle databases which may fail database operations if synchronous operations were executed, such as accessing Formulas or accessing the E3Query.Execute(True) method while consuming files .e3i or .e3o (error ORA-03127). This bug occurred since v4.0.14.
