Domain, E3 Server, and Hot-Standby
•E3 Server now supports unlimited E3DataAccess and E3AccessLayer connections, without consuming Elipse Power Viewer licenses or any other type of license.
•E3DataAccess Library does not consume a Elipse Power Viewer license anymore when connecting to an E3 Server, as long as the E3 Server version be 4.5.199 or newer. This type of connection is registered in E3 Server as "E3DataAccess".
•E3AccessLayer, used by EPM to collect data from Elipse Power, does not consume a Elipse Power Viewer license anymore when connecting to an E3 Server, as long as the E3 Server version be 4.5.199 or newer. This type of connection is registered in E3 Server as "E3AccessLayer.EPM".
•E3 Admin's License and Statistics windows now are resizable. They also identify correctly the connections via E3DataAccess Library and E3AccessLayer, differentiating them from Elipse Power Viewer connections. The names of the other connections were standardized on both windows. Added a Program column on Statistics window.
