E3Chart
E3Chart
•Fixed a problem that lead an E3Chart to not display in a Report footer when a page break appeared inside the footer. This bug occurred since v1.20.174.
•Fixed a GPF that could occur in E3Chart when updating queries in a Elipse Power Viewer with slow or unstable communication. This GPF occurred more easily if the application called the UpdateData and FitAll methods in sequence. This bug occurred since v4.0.50.
•Fixed a problem with an E3Chart ignoring non-numerical values, such as Null. This bug occurred since v3.2.105.
•Now E3Chart's configuration windows put brackets in field names, when needed. This bug occurred since v2.5.22.
•Implemented in E3Chart support for child queries with special characters in the name (E3Chart automatically adds brackets when needed). This bug occurred since v1.20.172.
•Fixed in E3Chart a problem when evaluating historical Pens with an expression in one of the axes, which could lead a Pen to always get a value of 0 (zero).This bug occurred since v4.0.168.
•Changed the E3Chart's drawing forced by Pens with queries, to show error status, even when there is no returned data. This bug occurred since v4.0.73.
•Fixed the behavior of editing external queries of E3Chart Pens, which caused the display of invalid values on the combo box to select a query. This bug occurred since v4.0.107.
•Fixed a problem in the CopyConfig method in E3Chart, which always connected the mark cursor of Pens in the destination E3Chart. This bug occurred since v3.2.89.
•Fixed a problem in the CopyConfig method, which kept the destination E3Chart redrawing itself and configuring the cursor to search mode. This bug occurred since v3.2.68.
