Connections
Connections
This section contains information about the Connection-type objects of the Electrical Model. The available connections on this section are the following:
•Branch
•Busbar Terminal
•Direct Current Branch
•Direct Current Jumper
•Direct Current Node
•External Node
•Graphical Vertex
•Jumper
•Junction Box Terminal
•Node
•Terminal
•Transmission Line Segment
