EnableHeartbeat |
Enables or disables sending a heartbeat message (sent at fixed intervals, which indicates that the server is active) between an Elipse Power Viewer and a server. In case Elipse Power Viewer stops receiving heartbeat messages, this means that a problem occurred, therefore connection must be aborted. The default value of this property is False.
