PublishLimit
PublishLimit
Number Configures a limit for publish requests of an OPC UA Driver, to avoid a request overload in OPC UA Servers. The default value of this property is 5 (five).
NOTES
•For applications created using versions previous to version 6.7 and opened in versions starting from version 6.7, the default value of this property is 0 (zero).
•Configuring this property with a value of 0 (zero) keeps the previous behavior of not imposing a limit for publish requests on the OPC UA Client-side.
