LineStyle |
Determines the line style of Ellipse, Rectangle, and Rounded Rectangle objects. Possible values for this property are described on the next table.
Available options for the LineStyle property
Option |
Description |
0 - rv2NoBorder |
Line remains transparent |
1 - rv2Solid |
Line appears solid (default) |
2 - rv2Dashed |
Line appears dashed |
3 - rv2Dot |
Line appears dotted |
4 - rv2DashDot |
Line appears with a dash-dot pattern |
5 - rv2DashDotDot |
Line appears with a dash-dot-dot pattern |
6 - rv2Double |
Line appears with double the width indicated in the LineWeight property |
