PositiveFlowIn |
This property creates a relationship between the signal of current or power measurements with their flow direction. If it is True, positive values represent a current or power input, that is, from this Terminal to a device, and if it is False, positive values represent a current or power output, that is, from this Terminal to other external components. This property cannot be changed while this object is active.
