ProtectionMode |
Receives an integer value from a *ProtectionMode-type Measurement, as if it were a shortcut to the Measurement value. This property informs which Protection mode is configured. Possible values for this property are 0: Excluded, 1: Included, 2: Blocked, 3: Test, or 4: Test and Blocked. This property makes it easy to create objects, Screen or data, that need information about the Protection mode, by simply reading this property, instead of searching for a Protection's child object. This is a read-only property.
