ShowMeasurementTimestamp |
When this property is set to True, displays one more column on the window of a PowerExplorer object, with Measurement's timestamp. This configuration applies to all tabs displaying Measurements, Analog, Discrete, and Protections.
Color configurations for this column are the same as the one for the column displaying Measurement values, that is, the DisplayBkColor property and the colors defined for quality. The default value of this property is False.
