RemoveScreenTab |
RemoveScreenTab(TabName)
Removes the tab indicated by the TabName parameter. Returns True if removal was successful, or False if the tab was not removed because it does not exist. This method generates a script error if the TabName parameter is the name of a default tab, "Analogs" (Analog tab), "Discretes" (Discrete tab), "Commands" (Commands tab), or "Protections" (Protections tab), or an empty String. The next script contains an example of using this method.
Sub CommandButton_Click()
Set PE = Application.GetPowerExplorer("Sub1.Breaker1")
PE.RemoveScreenTab "ChartTab"
